проблема с Scheduler
Здравствуйте....
у меня проблема с одним таском...
я пытаюсь вытащить с 3х таиблов результаты а потом их умножыть и прибавить друг другу...
но у меня проблема с sql-ом, никак не смог исправить...
он не работает после включения нечего не вводит в базу данных....
error log.
[/color][color=#282828]
Date: Tue, 12 Jun 2012 00:16:30 +0000
Error: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE member_id=' at line 1
IP Address: 95.104.65.208 - /forum/admin/index.php?adsess=36d479aee4f1d42b99f4b929e5db260b&app=core&module=system&section=taskmanager&do=task_run_now&task_id=51&tab=members
mySQL query error: UPDATE kate_pfields_content SET bounty= WHERE member_id=
| File        | Function        | Line No.          |
| admin/applications/members/tasks/bounty.php                                | [db_main_mysql].update                                                        | 129               |
| admin/applications/core/modules_admin/system/taskmanager.php               | [task_item].runTask                                                           | 325               |
| admin/applications/core/modules_admin/system/taskmanager.php               | [admin_core_system_taskmanager].taskManagerRunTask                            | 97                |
| admin/sources/base/ipsController.php                                       | [admin_core_system_taskmanager].doExecute                                     | 306               |
вот скрип
<?php
if ( ! defined( 'IN_IPB' ) )
print "<h1>Incorrect access</h1>You cannot access this file directly. If you have recently upgraded, make sure you upgraded all the relevant files.";
exit();
* @class task_item
* @brief Task to update the profile views from the temporary table
class task_item
* Object that stores the parent task manager class
* @var $class
protected $class;
* Array that stores the task data
* @var $task
protected $task = array();
* Registry Object Shortcuts
* @var $registry
* @var $DB
* @var $lang
protected $registry;
protected $DB;
protected $lang;
* Constructor
* @param object $registry Registry object
* @param object $class Task manager class object
* @param array $task Array with the task data
* @return @e void
public function __construct( ipsRegistry $registry, $class, $task )
/* Make registry objects */
$this->registry = $registry;
$this->DB = $this->registry->DB();
$this->lang = $this->registry->getClass('class_localization');
$this->class = $class;
$this->task = $task;
* Run this task
* @return @e void
public function runTask()
$this->registry->getClass('class_localization')->loadLanguageFile( array( 'public_global' ), 'core' );
$this->DB->build( array( 'select' => 'posts, COUNT(*) as posts', 'eco_points, COUNT(*) as eco_points',
'from'   => 'members', 'pfields_content',
'group'  => 'member_id'
// And finally, a complex build query showing all available parameters
											'select'		=> 't.*',
											'from'		  => array( 'members' => 't' ),
											'group'		 => 't.member_id',
											'add_join'	  => array(
																					array(
																							'select'		=> 'm.*',
																							'from'		  => array( 'pfields_content' => 'm' ),
																							'where'		 => 'm.member_id=t.member_id',
																							'type'		  => 'left',
																					array(
'select'		=> 'o.*',
																							'from'		  => array( 'profile_portal' => 'o' ),
																							'where'		 => 'o.pp_member_id=m.member_id',
																							'type'		  => 'left',
//$z =
$this->DB->execute();
//while( $this->DB->fetch( $z ) )
$sanoma = $o['time_spent'] + 80 * $m['eco_points'] / 4 + $t['posts'] * 100;
// Update...
$this->DB->update( 'pfields_content', "bounty=" .$sanoma, "member_id=" .$t['member_id'], FALSE, TRUE );
// $this->DB->update( 'pfields_content', 'bounty='. $sanoma, 'member_id=1', true, true );
// Delete from table
//$this->DB->delete( 'bounty' );
// Log to log table - modify but dont delete
$this->class->appendTaskLog( $this->task, $this->lang->words['task_bounty'] );
// Unlock Task: DO NOT MODIFY!
$this->class->unlockTask( $this->task );
спасибо заранее...
Что за переменные такие $o, $m, $t? Они нигде не определяются. Где фетч результата? У вас он закаментирован //while( $this->DB->fetch( $z ) ), к тому же еще неправильный - не присваивается переменной результат функции, неизвестный идентификатор $z.
$this->DB->build( array( QUERY ) );
while( $row = $this->DB->fetch() )
  //code
Изменено пользователем siv1987
  //code
спасибо большое, исправил проблему....
