DVD Soft
  • запись
    1
  • комментариев
    0
  • просмотров
    427
How to burn MP4/MPEG4 to DVD playable on a DVD player?
hath80
305 просмотров
So you have downloaded movies and taken videos in the MP4 (MPEG-4) video format. Want to play MP4 files on home DVD player in your living room sitting on the couch? Well, due to the limits of most DVD players' capabilities, the original MP4 files can't be played directly on regular home DVD players. Therefore, you need to convert and burn original MP4 files to a DVD format. And if you download the right software, you can burn MP4 to DVD. DVD Creator is exactly the professional MP4 (MPEG-4) to DVD converter that lets you convert and burn MP4 to DVD format. Well, this tutorial will show you the step-by-step guide on how to convert and burn MP4 to DVD format to play on home DVD player. Check it out now!
Step 1 Download DVD Creator
Download MP4 to DVD Converter to a known location. Once you've downloaded the program, double click the .exe file to install it.
Step 2 Load MP4 videos
Click on Load Video button in the upper left interface to locate MP4 (MPEG-4) files, and add them to this MP4 to DVD converter. Drag and drop loaded MP4 videos to the storyboard below to make further operation.
http://www.dvd-creator-converter.com/images/dvd-creator/step-load%20videos.jpg
Step 3 Edit MP4 movies (Optional)
The plug-in video editor lets you edit videos quickly and easily. Select a video file in storyboard and click on Edit selected video file button to crop, trim, add watermark, plug in subtitles or adjust video effects, according to your specific request within minutes.
Step 4 Burn MP4 videos to DVD
Once you've added videos to the program, now you can convert and burn MP4 (MPEG-4) videos to DVD directly. Of course, you may personalize your DVDs by adding transition effects, customize DVD menu templates, and edit downloaded movies, etc.
So, you just have finished burning MP4 (MPEG-4) to DVD, now you can play your MP4 files on home DVD player in your living room through TV. Also, now you may share your favorite movies with your friends. Enjoy.
More:
How to convert MP4 (MPEG-4) videos to a DVD?
AVI to DVD, WMV to DVD, QuickTime MOV to DVD, MKV to DVD, iTunes to DVD, M4V to DVD, Flip video to DVD, M4V to WMV, Burn/Copy Protected DVD, DRM Removal Tool, DVD Burning Tool, Mac DVD Burning Software, Video Converter Tool, Mac Video Converter, Professional DVD & Video Soft
0 комментариев
Рекомендуемые комментарии
