Warning!
The following errors must be rectified before continuing!
Please go back and try again!
INSERT INTO ibf_task_manager VALUES ('', 'Update Topic Views Counter', 'updateviews.php', 1144599177, -1, -1, 3, -1, 'ddce954b5ba1c163bc627ca20725b595', 0, 'Used when topic views are not incremented immediately', 1, 'updateviews', 0, 0);
Out of range value adjusted for column 'task_id' at row 1
sword
Warning! The following errors must be rectified before continuing! Please go back and try again! INSERT INTO ibf_task_manager VALUES ('', 'Update Topic Views Counter', 'updateviews.php', 1144599177, -1, -1, 3, -1, 'ddce954b5ba1c163bc627ca20725b595', 0, 'Used when topic views are not incremented immediately', 1, 'updateviews', 0, 0); Out of range value adjusted for column 'task_id' at row 1и все и дальше не устоновить в чем проблема ?*??
или подскажите как без установки устоновить его
3 ответа на этот вопрос
