Portal System 3.0.x by bfarber & IPB 2.3.4
  • 5 месяцев спустя...
To Get Portal Running...
# Go to tools and setting below, Upload XML settings file from your computer
# Open the Documentation folder, and select the file "mod_settings.xml" and import it. Then import mod_settings1.xml and mod_templates. Go to Manage Components in the Admin tab, and import the file: ipd_components.
Open Index.php
Find
// Short tags...
$ipsclass->input['act'] = isset($ipsclass->input['act']) ? $ipsclass->input['act'] : ( IPB_MAKE_PORTAL_HOMEPAGE ? 'home' : 'idx' );
if( is_array($ipsclass->input['act']) )
$ipsclass->input['act'] = ( IPB_MAKE_PORTAL_HOMEPAGE ) ? 'home' : 'idx';
// Check to make sure the array key exits..
if ( ! isset($choice[ strtolower($ipsclass->input['act']) ][0]) )
Replace With
// Short tags...
#$ipsclass->input['act'] = isset($ipsclass->input['act']) ? $ipsclass->input['act'] : ( IPB_MAKE_PORTAL_HOMEPAGE ? 'home' : 'idx' );
#if( is_array($ipsclass->input['act']) )
# $ipsclass->input['act'] = ( IPB_MAKE_PORTAL_HOMEPAGE ) ? 'home' : 'idx';
$ipsclass->input['_low_act'] = strtolower( $ipsclass->input['act'] );
if (! isset($choice[ $ipsclass->input['_low_act'] ][0]) )
#$ipsclass->input['act'] = 'idx';
#$ipsclass->input['_low_act'] = 'idx';
$ipsclass->input['act'] = 'component';
$ipsclass->input['_low_act'] = 'component';
$ipsclass->input['module'] = 'portal';
Then Find
$ipsclass->input['act'] = ( ! isset($ipsclass->input['act']) || $ipsclass->input['act'] == '' ) ? "idx" : $ipsclass->input['act'];
if ( !isset($ipsclass->input['_low_act']) OR !$ipsclass->input['_low_act'] OR $ipsclass->input['_low_act'] == 'idx' OR $ipsclass->input['_low_act'] == 'home' )
$ipsclass->input['_low_act'] = strtolower($ipsclass->input['act']);
Replace With
#$ipsclass->input['act'] = $ipsclass->input['act'] == '' ? "idx" : $ipsclass->input['act'];
if( $ipsclass->input['act'] == '' )
if ( !
'component' ) //$ipsclass->input['_low_act'] == 'idx' )
{ $ipsclass->input['_low_act'] =
$ipsclass->input['module'] = ($ipsclass->input['act'] ==
'component' || $ipsclass->input['act'] == 'module' ) ?
$ipsclass->input['module'] : '';
If You Dont Do The Edits You Can Use The Link /index.php?autocom=portal
If You Do The Edits Goto Admin Tab>Components>Manage Components And Click The Check Mark Beside Of The Portal To Change It To An X So The autocom Portal Link Will Not Show On Your Site
Спасибо огромное Tribalize с IP.Board
