Привет народ. Я не знаю русский, и только что я могу написать с помощью Google-а.
English:
Hi friends. I'm from Bulgaria and I think we have the same problem when we talk about cyrillic chars.
I'm using IPB 3.1.4 (english nulled version (for testing purposes)) and I have problem with uppercased char "Р" only in titles (in posts everything is ok).
Well, my database is utf8_general_ci.
In conf_global.php I have
$INFO['sql_charset'] = 'utf8';
In ACP charset is "UTF-8"
but the look in this way:
If I edit those two files:
classDbMysqliClient.php
// If there's a charset set, run it
if( $this->obj['sql_charset'] )
$this->query( "SET NAMES '{$this->obj['sql_charset']}'" );
$this->query( "SET CHARACTER SET '{$this->obj['sql_charset']}'");
$this->query( "SET character_set_connection = " .$this->obj['sql_charset']);
$res = mysqli_query($this->connection_id, "SHOW CHARSET LIKE '" . $this->obj['sql_charset'] . "'" );
if($charset = mysqli_fetch_row($res)) $this->query( "SET collation_connection = " . $charset[2] );
parent::connect();
return TRUE;
and classDbMysqlClient.php
$res = mysql_query($this->connection_id, "SHOW CHARSET LIKE '" . $this->obj['sql_charset'] . "'" );
return TRUE;
it looks like this:
Where I'm wrong ?
I think i'm using uf8 everywhere...
But this char is the problem only in the titles:
and
I'm sorry for that i use english, but I really don't understand russian, but if sould to translate it to russian, I'll do it, but I don't think will be better then my bad english, because I'll use google translate... But if is necessary I'll do it, because nobody can help me, but I think you can do !!!
beBoss
English:
//----------------------------------------- // If there's a charset set, run it //----------------------------------------- if( $this->obj['sql_charset'] ) { $this->query( "SET NAMES '{$this->obj['sql_charset']}'" ); $this->query( "SET CHARACTER SET '{$this->obj['sql_charset']}'"); $this->query( "SET character_set_connection = " .$this->obj['sql_charset']); $res = mysqli_query($this->connection_id, "SHOW CHARSET LIKE '" . $this->obj['sql_charset'] . "'" ); if($charset = mysqli_fetch_row($res)) $this->query( "SET collation_connection = " . $charset[2] ); } parent::connect(); return TRUE;and classDbMysqlClient.php
//----------------------------------------- // If there's a charset set, run it //----------------------------------------- if( $this->obj['sql_charset'] ) { $this->query( "SET NAMES '{$this->obj['sql_charset']}'" ); $this->query( "SET CHARACTER SET '{$this->obj['sql_charset']}'"); $this->query( "SET character_set_connection = " .$this->obj['sql_charset']); $res = mysql_query($this->connection_id, "SHOW CHARSET LIKE '" . $this->obj['sql_charset'] . "'" ); if($charset = mysqli_fetch_row($res)) $this->query( "SET collation_connection = " . $charset[2] ); } return TRUE;it looks like this:
Where I'm wrong ?
and
3 ответа на этот вопрос
