можешь подсказать почему у меня выходит такая проблема при установке ?
Driver Error
mySQL query error: SELECT id FROM flower_faq WHERE app='core' AND title = 'ПоиÑк'
SQL error: Illegal mix of collations (latin1_general_ci,IMPLICIT) and (utf8_general_ci,COERCIBLE) for operation '='
SQL error code: 1267
Date: Sunday 09th March 2014 07:25:02 AM
 Date: Sun, 09 Mar 2014 07:25:02 +0000
 Error: 1267 - Illegal mix of collations (latin1_general_ci,IMPLICIT) and (utf8_general_ci,COERCIBLE) for operation '='
 IP Address: 127.0.0.1 - /admin/install/index.php?app=install§ion=install&do=acphelp
 | File        | Function        | Line No.          |
 | admin/setup/applications/install/sections/install.php                      | [admin_core_tools_help].helpFilesXMLImport_app                                | 1481              |
 | admin/setup/applications/install/sections/install.php                      | [install_install].install_acphelp                                             | 139               |
 | admin/setup/sources/base/ipsController_setup.php                           | [install_install].doExecute                                                   | 258               |
If you are seeing this page, it means there was a problem communicating with our database. Sometimes this error is temporary and will go away when you refresh the page. Sometimes the error will need to be fixed by an administrator before the site will become accessible again.
You can try to refresh the page by clicking
Кодировка коллейшена базы - latin1_general_ci. Для форума нужна utf8_general_ci.
у меня кодирова эта utf8_general_ci.
всё равно
неправда, если бы сравнение везде было  utf8_general_ci , то ошибки бы не было.
Покажите результаты запросов
SHOW TABLE STATUS;
show variables like "collation_database";
show create table flower_faq;
show variables like "collation_connection";
show variables like "collation_server";
