Are you looking for staff? Developers? Designers? Or anything else? This application will help admins/moderators to find people to help in their boards.
Here's a quick rundown of some of the features for this resource:
  • Extra Fields
  • Module to add Positions on ACP (moderator, webdesigner, developer, etc)
  • Ability to inform how many places the position has. Example: you can create an application record to "hire" 3 moderators.
  • Ability to move the "winner" member to a group chosen group (you inform the group when you're adding the application record)
  • Ability to restrict the application by: Content count, Reputation points/likes, Number of days as member, Minimum age and groups
  • Module on ModeratorCP to view all pending records from all applications
  • Compatible with most important features from IPS 4.2 (Recommended Comments, Content Message, Reactions, Member History, Richer Embeds, etc.)
  • Integrated to the framework: Tag system, Follow System, Report system, Search system, Share Links, etc.
  • Moderator actions on applications and comments/reviews
  • Moderator permission to approve/reject applications
  • Ability to create RSS feeds from member applications
  • Etc.
