IBResource Опубликовано 7 Декабря 2015 Жалоба Поделиться Опубликовано 7 Декабря 2015 Power Tools Introduction Power Tools is a third party command line utility for Invision Power Suite developers. It aims to aid in development by packaging several useful command line script and applications together in one easy to use application. Installation If you are on Linux, there is an optional executable included in the release package which you can extract and copy to /usr/local/bin for convenience. Otherwise, just extract the included ptools.phar file to the directory of your IPS installation. Then, from your terminal window, navigate to the applications directory and run ptools.phar as you would any other PHP script from the command line,$ php ptools.phar Power Tools version 0.1Usage: command [options] [arguments]Options: -h, --help Display this help message -q, --quiet Do not output any message -V, --version Display this application version --ansi Force ANSI output --no-ansi Disable ANSI output -n, --no-interaction Do not ask any interactive question -v|vv|vvv, --verbose Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debugAvailable commands: classmap Generate a map of error codes for classes in an IPS application help Displays help for a command list Lists commands tinker Launches an interactive shell interpreter for an IPS installation proxy proxy:regen (Re)generates all proxy classes for the application Features Tinker Tinker is one of Power Tools most.. well, powerful features! The name tinker was inspired by Laravel's own "tinker" command, and it essentially operates in the same manner. Both are powered by PsySH, an application that provides an extremely powerful PHP REPL for your applications. Stop making your life difficult by executing arbitrary code in random modules for testing, or worse yet, actually trying to use the native PHP CLI interpreter. Need to test if your Item class is working correctly? Just pop into the REPL and give it a whirl! Everything in the tinker shell essentially works as your application does when run through the web browser. You can even get documentation on class methods right from within the interpreter, PsySh is a truly awesome tool. To learn more about it and all the features it offers you, check it out on PsySh.org. Proxy Classes Due to the nature of the IPS 4.x framework, several useful features of your IDE may become non-functional (suggestions, code completion, etc). This command will generate proxy classes for IPS (including 3rd-party applications), so your IDE will know how to use IPS style classes. This command was based off of @CodingJungle's own Proxy Class Generator script. Class Mapping The classmap command maps unique ID numbers to your applications class files. These ID numbers are then stored and maintained for use in error codes. By maintaining and actively using a proper error code scheme, you can easily and transparently map the location of errors that are triggered in production. For more information on this feature, refer to the original Classmap script. LicenseThe MIT License (MIT)Copyright © 2015 Makoto FujimotoPermission is hereby granted, free of charge, to any person obtaining a copyof this software and associated documentation files (the "Software"), to dealin the Software without restriction, including without limitation the rightsto use, copy, modify, merge, publish, distribute, sublicense, and/or sellcopies of the Software, and to permit persons to whom the Software isfurnished to do so, subject to the following conditions:The above copyright notice and this permission notice shall be included inall copies or substantial portions of the Software.THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS ORIMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THEAUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHERLIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS INTHE SOFTWARE. Перейти на сайт Invision Power Ссылка на комментарий Поделиться на других сайтах Прочее
