IBResource Опубликовано 14 Июля 2017 Жалоба Поделиться Опубликовано 14 Июля 2017 Power Tools Introduction Power Tools is a third party command line utility for Invision Power Suite developers. It aims to aid in development by packaging several useful command line script and applications together in one easy to use application. Installation If you are on Linux, there is an optional executable included in the release package which you can extract and copy to /usr/local/bin for convenience. Otherwise, just extract the included ptools.phar file to the directory of your IPS installation. Then, from your terminal window, navigate to the applications directory and run ptools.phar as you would any other PHP script from the command line, $ php ptools.phar Power Tools version 0.2Usage: command [options] [arguments]Options: -h, --help Display this help message -q, --quiet Do not output any message -V, --version Display this application version --ansi Force ANSI output --no-ansi Disable ANSI output -n, --no-interaction Do not ask any interactive question -v|vv|vvv, --verbose Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debugAvailable commands: classmap Generate a map of error codes for classes in an IPS application help Displays help for a command list Lists commands tinker Launches an interactive shell interpreter for an IPS installation generate generate:activerecord Generates an Active Record boilerplate class generate:content-comment Generates a Content Comment boilerplate class generate:content-item Generates a Content Item boilerplate class generate:content-node Generates a Content Node boilerplate class proxy proxy:regen (Re)generates all proxy classes for the application Features Tinker Tinker is one of Power Tools most.. well, powerful features! The name tinker was inspired by Laravel's own "tinker" command, and it essentially operates in the same manner. Both are powered by PsySH, an application that provides an extremely powerful PHP REPL for your applications. Stop making your life difficult by executing arbitrary code in random modules for testing, or worse yet, actually trying to use the native PHP CLI interpreter. Need to test if your Item class is working correctly? Just pop into the REPL and give it a whirl! Everything in the tinker shell essentially works as your application does when run through the web browser. You can even get documentation on class methods right from within the interpreter, PsySh is a truly awesome tool. To learn more about it and all the features it offers you, check it out on PsySh.org. Proxy Classes Due to the nature of the IPS 4.x framework, several useful features of your IDE may become non-functional (suggestions, code completion, etc). This command will generate proxy classes for IPS (including 3rd-party applications), so your IDE will know how to use IPS style classes. The proxy class generator can even automagically generate ibresource mappings to all your database columns! Class Generators Power Tools comes with several powerful and fully featured class generators for IPS Nodes, Items, Comments and generic Active Record classes. These generators take care of all the necessary boilerplate for you automatically. For example, generating a new Content Item class is as simple as running a single command and following the on-screen input prompts: phpnamespace IPSinductionTest;/* To prevent PHP errors (extending class does not exist) revealing path */if ( !defined( 'IPSSUITE_UNIQUE_KEY' ) ){ header( ( isset( $_SERVER[ 'SERVER_PROTOCOL' ] ) ? $_SERVER[ 'SERVER_PROTOCOL' ] : 'HTTP/1.0' ) . ' 403 Forbidden' ); exit;}class _Item extends IPSContentItem{ /** * @brief Application */ public static $application = 'induction'; /** * @brief Module */ public static $module = 'induction'; /** * @brief Database Table */ public static $databaseTable = 'induction_items'; /** * @brief Database Prefix */ public static $databasePrefix = ''; /** * @brief Multiton Store */ protected static $multitons; /** * @brief [ActiveRecord] ID Database Column */ public static $databaseColumnId = 'id'; /** * @brief Default Values */ protected static $defaultValues = NULL; /** * @brief Node Class */ public static $containerNodeClass = NULL; /** * @brief Comment Class */ public static $commentClass = NULL; /** * @brief Review Class */ public static $reviewClass = NULL; /** * @brief Database Column Map */ public static $databaseColumnMap = array( 'container' => 'category_id', 'author' => 'author_id', 'views' => 'views', 'title' => 'title', 'content' => 'content', 'num_comments' => 'num_comments', 'last_comment' => 'last_comment', 'last_comment_by' => 'last_comment_by', 'last_comment_name' => 'last_comment_name', 'last_review' => 'last_review', 'date' => 'date', 'updated' => 'updated', 'approved' => 'approved', 'approved_by' => 'approved_by', 'approved_date' => 'approved_date', 'pinned' => 'pinned', 'featured' => 'featured', 'locked' => 'locked', 'ip_address' => 'ipaddress' ); /** * @brief Title */ public static $title = NULL; /** * @brief Icon */ public static $icon = 'file'; /** * @brief [Content] Key for hide reasons */ public static $hideLogKey = NULL; /** * @brief Form Lang Prefix */ public static $formLangPrefix = 'induction_'; /** * @brief Reputation Type */ public static $reputationType = 'id';} Class Mapping The classmap command maps unique ID numbers to your applications class files. These ID numbers are then stored and maintained for use in error codes. By maintaining and actively using a proper error code scheme, you can easily and transparently map the location of errors that are triggered in production. For more information on this feature, refer to the original Classmap script. Перейти на сайт Invision Power Ссылка на комментарий Поделиться на других сайтах Прочее
